Date/Time: Thu, 28 Nov 2024 01:47:09 +0000
Rectangle config 3 not working properly
View Count: 234
[2023-06-11 22:16:29] |
User213504 - Posts: 69 |
I have Sierra V 2509 on a Windows 11 PC and I'm creating a new control bar 2 however one of the tool configs is not working properly. Rectangle config 3 does not extend to the end time as configured. I've attached a pic of the chart and the config window. The rectangle only shows the start time. All the other configurations I've set up are working correctly however there may be others. Ron |
rectangle config 3.png / V - Attached On 2023-06-11 22:15:18 UTC - Size: 34.76 KB - 84 views |
[2023-06-12 14:51:24] |
The configuration is showing a Start Time of 08:29:00 and an End Time of 08:30:00. This is why you are only seeing the rectangle as a bar. Make sure the End Time is set to something later - depending on what you want and what the Bar Period is set to.
[2023-06-12 14:57:45] |
Duh!!! Don't get old! Thanks.
