Date/Time: Thu, 28 Nov 2024 01:34:01 +0000
MakeHTTPPOSTRequest when sc.LastCallToFunction true not working when chart is closed
View Count: 268
[2023-06-11 21:01:00] |
@sstfrederik - Posts: 404 |
Hi, Executing MakeHTTPPOSTRequest during LastCallToFunction, does not work when the chartbook or chart is closed. It only seems to work when the study is removed. Closing the chart or chartbook seems to kill the request. The SC message log does indicate Making a HTTP POST Request, but nothing is received on the endpoint. Just updated to v2509. Thanks for looking into this. Fred |
[2023-06-13 18:52:50] |
Sierra_Chart Engineering - Posts: 17199 |
Each chart has its own HTTP object. Therefore, when the chart is closed, all of the outstanding requests are just deleted at that time. So this is just how it is.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-06-13 18:53:03
