Date/Time: Thu, 28 Nov 2024 01:43:40 +0000
Copying Footprint To Standalone DOM
View Count: 258
[2023-06-11 18:52:43] |
Stav - Posts: 104 |
Hi John, Sierra Chart I'm trying to copy my footprint chart(source #8) to my DOM(destination #2) DOM >> Chart Settings >> Chart Drawings >> Copy Chart Drawing From Chart #'s = 8 I have read all the documentation and have made sure that:- a) The footprint background is different from DOM b) That in the Global Settings >> Customizing Chart Drawing Shortcut Menu the Allow Copy To Other Charts menu item is there but still cant get the footprint to copy onto DOM not sure why. I have on the footprint chart just added the Open Market Depth Window (Trade >> Trading Chart DOM on)and configured it like my customized DOM but I have found that by doing it this way the attached DOM doesn't refresh as smoothly as my standalone Sierra Chart DOM. Any help on the above as always will be greatly apprciated. Kind Regards Stephen Is |
[2023-06-12 14:41:09] |
You can not copy the Numbers Bars to a Trading DOM. In general, a Trading DOM does not have the concept of bars, so there are only a few things that can be displayed on the Trading DOM. Refer to the following: Chart Trading and the Chart DOM: Adding Studies on a Trade DOM For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-06-12 14:50:44] |
Stav - Posts: 104 |
Hi John I thought this might be the case. Thanks for clearing this up. Kind Regards Stephen |
