Date/Time: Thu, 28 Nov 2024 01:27:58 +0000
No Price Scale on Charts
View Count: 458
[2023-06-11 14:42:13]
User502974 - Posts: 4
New user one week into 2 week free trial. Have been unable to open any chart that has a price scale. Only the price of the last tick is shown. Hopefully operator ignorance. I have searched support community, FAQ and not found this topic.
I have Serra installed on a Mac using CrossOver. Possibly some glitch from attempting to run Serra on a Mac, but hopefully there is a solution that I have found in 5the many settings.
Thanks,
User502974
[2023-06-12 13:16:00]
John - SC Support - Posts: 36350
We would really need to see a Screenshot of what you are seeing, but this is an odd situation (if you have not specifically changed colors), therefore it is most likely due to a MAC issue - for which we will not be able to help, but we need to see an image first.
[2023-06-12 17:52:09]
John, Thanks much for responding to my plea for help, but I am unable to include a screen image???
The instructions for attaching a screen image in this forum are not consistent with Serra Charts I have on my computer. At best a link was produced but when opened in a browser window there is either a blank or black page. Using the Message Log link above I did post a copy of the log, below if of any value. A have created a screen shot with the Mac built in screen shot tool, but cannot paste it here???
(Log removed)
https://www.sierrachart.com/image.php?Image=1686591135396.png
Thanks Again!!!!!
Date Time Of Last Edit: 2023-06-13 14:52:33
[2023-06-12 21:32:41]
Unfortunately, the Message Log doesn't give us any of the information we need, and everything looks fine in the log. We really need a screenshot.
The built-in screenshot tool sometimes gives a blank image if you are covering up the window prior to it getting the screenshot together, or if the program is not maximized.
Just attach the image you took using the built-in Mac tool by following these instructions for attaching a file:
https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile
[2023-06-12 22:53:34]
Try this link. Works in the browser. Will try in Preview.
https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=82188
imageSierra Screen Shot.png / V - Attached On 2023-06-12 22:45:32 UTC - Size: 1.04 MB - 100 views
[2023-06-13 14:52:01]
Sierra_Chart Engineering - Posts: 17199
You need to check the Chart Text Color settings:
Graphics Settings
Check all of the color settings.
[2023-06-13 14:59:00]
The particular color setting you want to check is the following:
- Chart Values Scale Text Color
It looks like it is set to White, which is the same as your background.
[2023-06-13 18:18:00]
PROGRESS, MAYBE!! Please pardon my ignorance!! Am I correct that Chart Settings apply to a given chart that is selected, and Global Setting apply to all charts. Can one override the other?
https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=82234
THANK YOU!!!!
imageSierra Chart Screen Shot 2.png / V - Attached On 2023-06-13 18:07:07 UTC - Size: 998.84 KB - 99 views
imageSierra Chart Screen Shot 2.png / V - Attached On 2023-06-13 18:10:55 UTC - Size: 998.84 KB - 86 views
[2023-06-13 18:45:54]
Refer to the following:
Graphics Settings: Using Different Color and Graphics Settings for Specific Charts
