Date/Time: Thu, 28 Nov 2024 01:38:13 +0000
packages
View Count: 246
[2023-06-11 14:12:17] |
User220637 - Posts: 10 |
Why I can t open 5 min futures chart? Does my package support that? If not, what package do I need for FUTURES? Thank you
[2023-06-12 13:12:07] |
You should not have any issue getting a 5 minute chart with the package you have. This is available with any package. Refer to the following for how to change the Bar Period if a chart: Changing Chart Bars Period Also refer to the following for reasons why you may not be able to to change the Bar Period for a chart: Unable to Change the Bar Time Period for Charts For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-06-12 14:12:44] |
I can t, I can open ES weekly or daily but not 5min or 10min. Please explain step by step what should I do. Thank you
[2023-06-12 14:27:49] |
It s OK, I have done it
