Date/Time: Thu, 28 Nov 2024 01:33:35 +0000
[Programming Help] - Issue with Alert based on Num Bars Calc Values
View Count: 309
[2023-06-11 02:04:11] |
jivetrader - Posts: 410 |
I am seeing unusual behaviour from this formula and I would appreciate any help: ID61 = Num Bars Calc Values SG42 = prive value of the bar's POC (yes?) Color Bar based on alert condition: ID61.SG42=ID61.SG42[-1] I believe this should highlight when a bar POC equals the previous bar's POC, but I am seeing erratic highlighting. current bar POC = bar[-1] POC is what I am trying to do, in case I have got it wrong. Thanks in advance. |
[2023-06-11 14:10:55] |
User431178 - Posts: 544 |
This might help: Study/Chart Alerts And Scanning: The Effect of the Value Format on Identifier Values or this Study/Chart Alerts And Scanning: Use Full Precision When Evaluating Alert Formula |
[2023-06-12 13:10:01] |
Refer to the following, as it contains the information for your issue: Numbers Bars: Referencing Numbers Bars Calculated Values Subgraphs in Alert Formulas For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
