Date/Time: Thu, 28 Nov 2024 01:32:43 +0000
Is it possible to offset Fill and exit flags on a chart?
View Count: 223
[2023-06-10 21:19:53] |
User547290 - Posts: 58 |
I would like to move the fill and exit flags out of the way of the chart, or put them against the upper or lower edge of the chart. I don't use them because of this, but would like to. Thanks |
Attachment Deleted. Dimmer_2_lNMTYB2n0G.png / V - Attached On 2023-06-10 21:19:10 UTC - Size: 37.48 KB - 72 views |
[2023-06-12 13:03:23] |
There is not a way to offset the Order Fills.
