Date/Time: Thu, 28 Nov 2024 01:27:59 +0000
chartbook broken (empty) after updating to 2509
View Count: 252
[2023-06-10 18:48:15] |
VLiviu - Posts: 223 |
Hello all, I just did update to latest version (2509) and one of my chartbooks has lost all my charts. Its empty now. I am talking about ES chartbook with DOM, footprint etc and other charts I've made inside. Not sure what exactly happened, I was playing in reply mode, doing my thing and then after stopping it, I closed SC and clicked to save everything. Now I came back and its empty. Please advice. Thank you! |
[2023-06-11 11:35:09] |
Sierra_Chart Engineering - Posts: 17199 |
Use a backup Chartbook: Chartbooks (Workspaces): Accessing a Backup Chartbook File Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-06-11 12:01:05] |
Thanks Already found it there. Appreciate it! |
