Date/Time: Thu, 28 Nov 2024 01:27:15 +0000
[User Discussion] - Using both Interactive Brokers and Teton
View Count: 604
[2023-06-09 18:20:54]
User805518 - Posts: 24
I need two info if someone can answer:
- Is it possible to have teton order routing for CME (and Denali feed) and Interactive Brokers with italian IDEM Market on the same platform?
If yes:
- how can I use them? I mean, when I want switch to Italian market and go with Interactive B. have to choose a menu and go with Italian Market or is it more difficult?
- last but not least, using SC with Interactive B. is would present many trouble or difficult that should me think about that type of connection?
- how good would be the feed (Italian) through SC from IB?
Reason for asking this is. I really like SC but have to trade IDEM market also, and not want having learn/use two different platform.
Thanks very much
Alessandro
[2023-06-09 18:53:54]
John - SC Support - Posts: 36350
You can use Sierra Chart to chart and Trade the IDEM market with Interactive Brokers, as longa as they have the data for it (as you are probably aware, we do not have the data for that exchange). You would just enter the appropriate symbol for Interactive Brokers to get that data into the system.
The best way to trade using both Teton and Interactive Brokers is to have 2 different Sierra Chart installations. One will be connected to Teton and the other connected to Interactive Brokers. Refer to the following information:
Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart
We will let others comment on their experiences with Interactive Brokers.
[2023-06-09 21:43:19]
Thank John for the answer that really sounds good.
Hope someone can give feedback about Interactive B.
