Date/Time: Wed, 27 Nov 2024 23:39:55 +0000
[Programming Help] - Flex Renko Reversal Bar Next Bar as entry
View Count: 316
[2023-06-09 18:11:34] |
User469312 - Posts: 97 |
I am looking for help with flex Renko Bars. With the parameters I have set for the Reversal Bar I am trying to set the next bar as the trigger (for Long or Short). Anyone able to help/point right direction?
[2023-06-20 13:48:09] |
Sierra_Chart Engineering - Posts: 17198 |
We are not understanding what you are wanting to do. What exactly do you mean by this: set the next bar as the trigger (for Long or Short).
[2023-06-20 14:16:03] |
I apologize for not being clear. I was trying to say is, when a reversal bar is generated the next bar or 2 (if those bars are higher or lower from that reversal bar) it will be a short signal or long signal. Basically, when a reversal bar is generated, is the next bar or 2 > than that reversal bar in the direction of the reversal bar. If > than a signal is generated again, sorry for not being clear. |
[2023-06-20 15:15:20] |
Sawtooth - Posts: 4120 |
Use formulas like these:Long: =AND(C[-1] < O[-1], C > O, H > H[-1]) Short: =AND(C[-1] > O[-1], C < O, L < L[-1]) |
[2023-06-20 15:46:38] |
I cannot thank you enough for this help. very much appreciated
