Date/Time: Wed, 27 Nov 2024 18:39:26 +0000
Alerts
View Count: 317
[2023-06-09 17:21:27]
User585993 - Posts: 83
What formula should I use if I want an alert when the cumulative delta is: 500K ( negative alert) and -500K ( positive alert)
[2023-06-09 18:33:17]
John - SC Support - Posts: 36331
The Close subgraph gives you the actual Cumulative Delta value at any time, so you would want to test against this. The formula for one of these is the following:
=ID1.SG4 > 500000
If you want to test for either situation, it would be the following:
=OR(ID1.SG4 > 500000, ID1.SG4 < 500000)
ID1 is the ID of the Cumulative Delta study.
[2023-07-10 15:56:24]
is there a way to limit the alert to a specific time period like from 3:00pm-3:05pm?
[2023-07-10 16:02:40]
I Have this formula so far
=AND (ID2.SG4 > 50000, BARTIME>TIMEVALUE("14:59:59"),BARTIME<TIMEVALUE("15:00:01"))
