Date/Time: Thu, 28 Nov 2024 01:23:44 +0000
sc.ReconnectToExternalServiceServer not working after sc.DataFile
View Count: 259
[2023-06-09 15:27:52]
Berliner JFK - Posts: 45
I use ACSIL to perform an automatic rollover, i.e.
sc.DataFile = ROLLOVER_SYMBOL;
This works good.
After rolling over the symbol, though, I wanted to reload the chart as well, i.e.
sc.ReconnectToExternalServiceServer = true;
For some reason, when I follow the symbol change with the reconnect in ACSIL, the reconnect doesn't seem to work.
I'm used to seeing the message log scroll for 10 seconds when there's a programmatic reconnect, but there's nothing after rolling over the symbol.
Here is my code again, complete:
Could you please help me understand why this only results in a symbol change, but no reconnect afterwards?
Thanks!
[2023-06-09 16:04:05]
Sierra_Chart Engineering - Posts: 17199
Reconnecting to the data feed in this case is unnecessary and does not cause any kind of reload:
[2023-06-12 11:30:32]
Refer to this function:
sc.StartDownloadHistoricalData()
[2023-06-12 12:18:35]
I realize now that what I wanted to achieve after rollover was:
1. historical download
2. reload
3. recalculate
In the past (not rollover) sc.ReconnectToExternalServiceServer worked for this.
Now I will now use sc.StartDownloadHistoricalData after a symbol change to achieve the above.
Date Time Of Last Edit: 2023-06-15 01:14:51
