Date/Time: Thu, 28 Nov 2024 01:31:28 +0000
es Micro Mini Rollover problem
View Count: 448
[2023-06-08 16:49:57] |
User360283 - Posts: 504 |
I rolled over the F.US.MES.M23 this M expecting to the N monthly contract. Instead I got the U contract. F.US.U23 This show very little volume on the DoM. When I manually set the contract to the N contract I get errors. Help please Thanks |
[2023-06-08 17:18:53] |
User431178 - Posts: 544 |
There is no N contract for MES - H, M, U, Z that is all. https://www.cmegroup.com/markets/equities/sp/micro-e-mini-sandp-500.contractSpecs.html https://www.cmegroup.com/markets/equities/sp/micro-e-mini-sandp-500.calendar.html Couple more days and volume on U contact will pick up. |
[2023-06-09 10:43:29] |
I have been a Sierra customer for more than 10 years trading ES futures. It is very frustrating when Options roll or expire. All price info and drawings of the previous contract period VANISH !!! There must be a Better way! 1. Charts need an easy way to Roll the same as how it works in the Quote Board. 2. Charts need a way to maintain previous quarter data and drawings A friend showed me on a different chart provider something called "Continuous" that solved my problems How can I have "Continues" with Sierra? Help pease Thanks |
[2023-06-09 14:49:30] |
For a Continuous Contract refer to the following: Continuous Futures Contract Charts When you roll over a contract, you can also roll over the drawings. Refer to the following: Changing to a New Futures Contract Month: Allowing Lines and Other Chart Drawings From Other Contract Months to Appear on the Current Contract For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-06-12 20:39:29] |
Currently I am trading using Amp Global with NO Sierra support and CQG CQG now steal 38% of my daily profits and increases my daily losses by 50% Yet I am hesitant to switch to Denali to get continuous contacts. I guess I am thinking about the Devil I know! LOL The reason I am looing at continues contracts is both not having the charting redos at every expiry and to be able to get 50, 100, and 200 dat MAs. If I switch to Denali will I still be able to trade with Amp? Can you please provide an estimate of how much Denalis will cost me? If I switch to Denali would I be able to switch back to CQG? Thanks |
[2023-06-12 22:03:06] |
We see that you are already using, and have been using for some time, the Denali Exchange Data Feed. We assume you are referring to the "Teton Order Routing Service". This is available with AMP. There are no costs for using the Teton Order Routing Service. As such, you will save approximately $0.10 per side that you are currently paying for CQG routing. You can always go back to CQG. The information for the Teton Order Routing Service can be found here: Sierra Chart Teton Futures Order Routing For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
