Date/Time: Thu, 28 Nov 2024 01:27:09 +0000
How to change back volume
View Count: 210
[2023-06-08 14:36:32] |
Poparocks - Posts: 15 |
I use to have a bar on the side of my chart that would show were liquidity was making it easier to trade. For some reason it has changed all of a sudden, was this because I changed the session times in the chart? I changed them back and it still did not resolve the issue. How do I get back to seeing all the liquidity?
Attachment Deleted. |
[2023-06-08 18:43:50] |
Those items are the DOM Graph. Refer to the information here: Trade Menu: Draw DOM Graph on Chart (Trade menu) Based on the images you show, it looks like you only had 1 level of Market Depth being displayed, which is why you only had the 1 bar level. Now you have more than that, which is why you have multiple bars. If you only want the 1 bar level of Market Depth, then refer to the following: Chart Settings: Maximum Market Depth Levels (Chart >> Chart Settings >> Market Depth menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
