Date/Time: Wed, 27 Nov 2024 14:22:52 +0000
SC randomly changed the very large fonts
View Count: 407
[2023-06-08 14:34:52]
Kelamik - Posts: 13
SC randomly changed to very large fonts on price scale, time scale, window size, menus, etc... When I run other application on the same PC the scaling and font are correct. This only affects SC. Is this a known occurrence, if so how do I revert it back to what it was before?
[2023-06-08 14:35:14]
Sierra_Chart Engineering - Posts: 17193
Refer to:
Graphics Settings: Font Sizes Unexpectedly Changing
[2023-07-31 18:28:42]
Dan the Man - Posts: 89
I loaded SC today and all the Chart Text font size unexpectedly changed to 5 point.
I have over a 100 charts that are affected.
How do I change the Chart Text font size back to my orgainal size (10 point) without have to change each chart one at a time.
I tried setting the text size using - Global setting> Chart Text - then saved and restarted SC but that did not help.
I referred to Graphics Settings: Font Sizes Unexpectedly Changing
Regards,
[2023-07-31 19:47:58]
Do you have the font size specified for each individual chart?
[2023-07-31 20:12:26]
Kelamik - Posts: 13
I noticed that this issue occurs when I disconnect one of my 4 monitors and fonts change when that happens but this does not happen consistently. To fix it I have to go through every single font in Global Graphic Settings and manually change it.
[2023-07-31 20:19:33]
Hi John,
To answer your question.
All 100 charts have the same font size.
When I go to the various charts and under Chart-Graphics Settings - each font size was changed to 5 point.
Regards,
Date Time Of Last Edit: 2023-08-01 12:39:26
[2023-08-01 13:23:48]
We recommend using global graphics settings for each chart so you only have to change the font in one location. Which would be through Global Settings >> Graphics Settings.
[2023-08-01 13:42:13]
I tried that and it does not work
[2023-08-01 15:03:19]
John - SC Support - Posts: 36310
You would have to switch your charts to use the Global settings. Refer to the following:
Graphics Settings: Using Different Color and Graphics Settings for Specific Charts
