Date/Time: Thu, 28 Nov 2024 01:40:18 +0000
Scanning US STOCKS for the first time
View Count: 263
[2023-06-08 14:18:19] |
User361939 - Posts: 165 |
Hello, I create Watchlist containg all symbols for NASDAQ. Now i am running scann for the first time. Scan is done. ( my scan didn't show any stocks that met creteria of my alert) If i click on any symbol and check chart it seems that it started downloading data at the moment i click to see chart. (take a look into attachment) So my question is, did scan really happened? Or i need to click on every symbol so it actually loads it self into chart? It is confusing for me. Regards Date Time Of Last Edit: 2023-06-08 14:19:37
sierrascan.png / V - Attached On 2023-06-08 14:18:07 UTC - Size: 38.29 KB - 83 views |
[2023-06-08 15:01:02] |
Ok i found answer myself, so for traders in futures First you need to download all symbol for assocatied watchlist by clickicng: EDIT-<DOWNLOAD DATA FOR ASSOCIATED WATCHLIST Than you can make a scan. Date Time Of Last Edit: 2023-06-08 15:01:25
