Date/Time: Thu, 28 Nov 2024 01:43:50 +0000
data
View Count: 333
[2023-06-08 06:18:54]
TheFibber - Posts: 83
hi there is a problem with a lot of intraday data...fake data for MCD JPM HD and so on. in the attachment you can see intraday 12H of hd as an example
imagehd.JPG / V - Attached On 2023-06-08 06:18:44 UTC - Size: 215.62 KB - 90 views
[2023-06-08 12:31:00]
sorry but can you resolve the problem? i need to do my analysis
thanks
[2023-06-08 12:32:53]
Sierra_Chart Engineering - Posts: 17199
This has been resolved. Follow the instructions here:
Data Errors or Spikes in Charts, Flat or Flat Line Graph, Compressed Graph, Errors with Date/Time Values: 2.1.2 Deleting and Re-downloading Data. (Easier and Recommended Method)
Also that data was transmitted by the exchange on the CTA feed.
[2023-06-08 12:40:18]
Actually we can still see a problem with some of the symbols. For now just do not include the evening session until we look into this some more.
[2023-06-08 13:03:52]
it doesn't work. if i delete and download to the same chart it remain the same. WHEN i create a new chartbook and download the same ticker it works. but when i set session fromm 00:00 to 23:59 the error reappear. so i delete the file from the directory \data and redownload it but it is the same!!!!
can you take me in control with teamviewer?
[2023-06-08 13:42:09]
Refer to post #4. Remove the evening session data for now!
No we are not going to be doing any remote session. That is not needed.
[2023-06-08 13:50:46]
i don't find post #4 can you link me here that post?
thanks
[2023-06-08 13:52:01]
and : is there a problem you are going to fix?
[2023-06-08 14:02:30]
Yes of course! The NYSE transmitted erroneous data last night after the close! this data was from the exchange!
We developed a filter this morning for it but it is not working as expected. We need to research this.
[2023-06-08 14:34:35]
