Date/Time: Thu, 28 Nov 2024 01:27:25 +0000
How do I get trend lines to not move on a tick chart?
View Count: 435
[2023-06-08 01:33:55] |
User776992 - Posts: 8 |
How do I get trend lines to not move on a tick chart? If I choose the Line tool and I go and draw a trendline as the price moves around the line it skews it making it off-kilter. I've tried using the lock line feature in this tool and the line still moves as the price passes through it. It's very frustrating as even in a fast-moving market I have to keep adjusting my lines. I've even tried using the Ray tool and it does the same thing. So I literally can't draw channels or trendlines and have them stay accurate. Any help in getting these lines to be immovable would be wonderful. I think that some people might call or refer to a tick chart as a Range chart. I usually use a 233 tick chart on the NQ. Thank you, David B. |
[2023-06-08 08:27:28] |
Sierra_Chart Engineering - Posts: 17199 |
Refer to this page: Lines/Rays or Other Chart Drawings Move After Drawing Them There is no further help we can provide. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-06-08 08:38:42
