Date/Time: Thu, 28 Nov 2024 01:26:07 +0000
display lines from one chart to another chart
View Count: 261
[2023-06-07 15:43:54]
User937135 - Posts: 2
Good morning there, can you help me please, I have a problem with my SC, I am trying to see ,the draw in another chart, but It is imposible, I dont know why.
I AM GOING TO SEND A PICTURE FOR YOU ALL AND CAN UNDERSTAND ME,
What I want is for a line that I paint on the chart to be displayed on the other chart, I have entered the functions but it is impossible.
imageIMG_20230607_173359_479.jpg / V - Attached On 2023-06-07 15:43:45 UTC - Size: 116.08 KB - 78 views
[2023-06-07 15:45:59]
John - SC Support - Posts: 36350
It is hard for us to tell for sure, but since the time period chart #8 is 240 minutes and the time period for the chart you are copying to is 1 day, the drawings may be copied properly, but only displayed within the span of the one day, therefore they would only be a dot within the daily bar.
Make sure the lines are extending across at least a few days in order to view them in the Daily chart.
