Date/Time: Tue, 26 Nov 2024 22:22:49 +0000
1yr Treasury Notes - can SC do a chart of the actual interest rates?
View Count: 1599
[2014-06-30 17:20:30] |
User73940 - Posts: 11 |
Can I create a chart of the 1 yr Treasury Notes actual interest rates? And, if I create chart of TNU4 and also TN# (daily continuous) the prices are way off. Am I missing something? IG |
[2014-06-30 19:49:57] |
Yes you can. You can use the Sierra Chart Historical Data Service for this: http://www.sierrachart.com/index.php?l=doc/SierraChartHistoricalData.html#UsingSCHDS The symbol is: $TNX What specifically is wrong with the prices of TNU4? It should have accurate futures prices for the market. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-06-30 20:16:14] |
Thanks for the info. I tried loading #TNX but since my data is with Infinity it seems it doesn't allow this data....how can I find out? And, I've attached two charts: ZTU4 and ZT# and the data for today is correct but yesterday and farther backwards its way off. Suggestions? IG |
ZTU4_ZT#_Datat_2014-06-30_13-08-01.jpg / V - Attached On 2014-06-30 20:15:06 UTC - Size: 299.91 KB - 373 views |
[2014-06-30 23:15:00] |
I figured out why ZTU4 and ZT# are different. On ZT# it looks like when they switch over from the ZTM4 to ZTU4 contracts it causes a gap (ZT# switches over at the end of the month vs ZTU4 switches over much sooner). Thanks. IG Date Time Of Last Edit: 2014-06-30 23:17:25
[2014-07-01 02:55:54] |
Looks like you have a Sierra Chart account through Infinity. To use the Sierra Chart Historical Data Service, you will need a direct account: https://www.sierrachart.com/index.php?page=doc/doc_DirectAccount.html This will be the only way to access the $TNX data. For continuous futures contract charts, rather than using the #, we highly recommend using the new Continuous Futures Contract feature documented here: https://www.sierrachart.com/index.php?page=doc/doc_ContinuousFuturesContractCharts.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
