Date/Time: Wed, 27 Nov 2024 21:46:13 +0000
FXCM feed - Treasury
View Count: 393
[2023-06-07 09:22:33]
User365411 - Posts: 189
Please can you add the 10USNote and FED30D?
https://www.fxcm.com/markets/help/c/product-guide/treasury/
TY
[2023-06-27 10:33:08]
The 10USNote that you recently added worked for just few days, maybe until june 21, now realtime doesn't work and delete and download intraday some times fail and returns the red rectangle error (img attached)
Tested on multiple installation and release of SC.
2USNote and 5USNote added in the past works correctly.
And can you check the DJFXJPY too? There is no data at all.
TY
Date Time Of Last Edit: 2023-06-27 10:36:11
image10USNote[M] 60 Min #2 2023-06-27 06_23_02.775.png / V - Attached On 2023-06-27 10:32:54 UTC - Size: 46.12 KB - 58 views
[2023-06-28 08:59:15]
Sierra_Chart Engineering - Posts: 17198
We will not be spending any further time on this. We will not be adding any additional FXCM symbols.
If the symbols work they work . If they do not work they do not work. There will be no further time on this.
We recommend using the Delayed Exchange Data Feed and accessing the CBOT futures:
We also have NASDAQ Global Indexes:
https://www.sierrachart.com/index.php?page=doc/DenaliExchangeDataFeed.php#NASDAQGlobalIndexDataFeed
Date Time Of Last Edit: 2023-06-28 09:00:29
[2023-06-28 10:20:16]
Actually we found the problem with the symbols we added. You should be getting current and historical data for them now from all servers.
Date Time Of Last Edit: 2023-06-28 10:20:29
