Date/Time: Mon, 16 Sep 2024 19:16:23 +0000
Update Interval
View Count: 1039
[2014-06-30 14:49:02] |
TI Anon - Posts: 36 |
What is the update interval for "Market Stats" supplied by SC?
[2014-06-30 16:22:05] |
2 times a second. This is documented here: http://www.sierrachart.com/index.php?l=doc/SCMarketStatistics.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
