Date/Time: Thu, 28 Nov 2024 00:33:30 +0000
CME lumber future 'LB' out-of-date?
View Count: 384
[2023-06-06 13:07:35] |
Ed Goppelt - Posts: 41 |
It looks to me like Sierra Chart has not updated its metadata for the CME lumber future (old symbol LB or LBS, new symbol LBR). See: https://www.cmegroup.com/articles/faqs/lumber-futures-faq.html If I am wrong about this, please point me to the CME page that contains the technical specifications for the SC symbol 'LB'. Thank you. |
[2023-06-15 20:09:59] |
User500207 - Posts: 5 |
I was going to ask that question also LBS now symbol is LBR Lumber futures IS there a way to Refresh denali data or download Current symbols??
Date Time Of Last Edit: 2023-06-15 20:11:41
[2023-06-16 10:38:11] |
Sierra_Chart Engineering - Posts: 17199 |
This has been done. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Although not for CQG but we will do that now. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-06-16 10:55:39] |
CQG symbol settings have been updated. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-06-16 10:55:45
