Date/Time: Tue, 26 Nov 2024 22:37:45 +0000
multiple monitors with main window
View Count: 1657
[2014-06-30 12:59:40] |
ktfroy - Posts: 85 |
I want to use the main window stretched across multiple monitors and not detach charts. Is there a way to set a chart so that when it is maximized it will fill only that particular charts residing monitor?
Date Time Of Last Edit: 2014-06-30 14:36:07
[2014-06-30 16:21:27] |
Not if that chart window is within the main Sierra Chart window. It will fill the entire Sierra Chart window when it is maximized.
[2014-07-01 14:21:29] |
Can this be fixed?
[2014-07-01 15:38:46] |
There is nothing to fix. This is how the operating system handles this.
[2014-07-01 17:10:07] |
Okay, I mispoke perhaps suggesting it was a glitch. How about working on the option so as to increase functionality? Would that be a possibility? |
[2014-07-01 17:10:45] |
No. This is not something that we would add.
