Date/Time: Thu, 28 Nov 2024 01:38:52 +0000
P&F
View Count: 345
[2023-06-06 07:08:25]
Bram - Posts: 25
Dear Mr, Mrs,
is there a solution to have the X's and O's on a tick size so it the bottom and top of an X or O is equivalent to 0.25 tick sizes
ii use graph draw type P&F in chart settings
many thanks in advance
[2023-06-06 10:23:04]
Sierra_Chart Engineering - Posts: 17199
We are not understanding this. Do you want each X and O to be equal to 1 tick?
[2023-06-06 17:35:19]
Bram - Posts: 25
no, that's not it. my chart settings/ bar period /settings is 3/1. that's my setting. that's fine. it's just when sieera charts prints X or O the bottom of the X_ isn't a 0.25 equivalent.
[2023-06-06 19:56:34]
Ok, sounds like what you are looking for is not supported.
[2023-06-07 17:37:06]
Bram - Posts: 25
isn't there a way to decrease the hight of the x's and o's like in word you have 7.8.9.10.11......
[2023-06-07 20:11:09]
John - SC Support - Posts: 36350
In this case the X's and O's are set to be the height of the Point and Figure Box Size. The reason you are seeing the X's and O's stretch between ticks is because you are using an Odd number for the Box Size. If you use an even number, then the X's and O's can be evenly distributed on the ticks.
