Date/Time: Fri, 22 Nov 2024 08:10:29 +0000
Compile error for GetStudyPersistentVariablesFromChartUsingID
View Count: 2166
[2013-05-02 16:24:24]
joshtrader - Posts: 488
const s_sc::s_PersistentVariables * p_PersistVars = GetStudyPersistentVariablesFromChartUsingID(1, 3);
This is returning an error:
":46:102: error: 'GetStudyPersistentVariablesFromChartUsingID' was not declared in this scope"
At the top I have:
#include "sierrachart.h"
What am I missing? I see the definition in sierrachart.h, so I'm not sure what's up.
Date Time Of Last Edit: 2013-05-02 16:25:56
[2013-05-02 16:33:25]
You need to prefix it with sc.
Date Time Of Last Edit: 2013-05-02 16:43:03
[2013-05-02 16:40:11]
I don't understand what "you need to proceed it with sc." means.. I copied the code directly from the SC documentation.
Date Time Of Last Edit: 2013-05-02 16:42:41
[2013-05-02 16:44:23]
The documentation has been corrected and there was a slight dictation error with the prior post. It has been corrected.
[2013-05-02 16:57:07]
OK thank you, it is compiling now.
With this study I am trying to set the main price graph scale top and bottom to be the same as that of another chart. I have the values now, but is there a way for me to set the top and bottom value of the primary region's scale? I can do it for a study using sc.ScaleRangeTop and sc.ScaleRangeBottom, and I see the sc.BaseGraphScaleRangeType to set the , but do not see how to set the top and bottom values. I tried sc.BaseGraphScaleRangeTop but this does not exist.
[2013-05-03 00:06:35]
No, this is not supported. We will have to get to it later on.
