Date/Time: Thu, 28 Nov 2024 03:44:24 +0000
SierraChartStudies_64.dll Is missing
View Count: 266
[2023-06-04 19:12:44]
kman11 - Posts: 1
I ma trying to figure out how to get these studies back. I have uninstall Sierra charts and re dowloaded and still get the same error
imageScreenshot 2023-06-04 at 12.11.45 PM.png / V - Attached On 2023-06-04 19:12:00 UTC - Size: 18.71 KB - 74 views
[2023-06-05 08:33:24]
Sierra_Chart Engineering - Posts: 17199
The problem is you are not installing Sierra Chart into the correct location on your computer. You are installing it into a temporary system folder. Do not do that.
We want you to do a new installation of Sierra Chart into this folder:
C:\SierraChart
Do not use any other folder.
Instructions:
Software Download: Installation and Upgrading Instructions
You can then copy existing Chartbooks you have to the new installation:
Transferring Sierra Chart Settings and Data From Existing Installation to New Installation
Date Time Of Last Edit: 2023-06-05 08:34:07
