Date/Time: Tue, 26 Nov 2024 22:25:47 +0000
Force SierraChart to download historical intraday data from IB, not SC server
View Count: 1289
[2014-06-30 07:13:12] |
rc7rader - Posts: 144 |
Is there a way to force SierraChart to download historical intraday data from IB server and not from SC server? The stock CELG had a stock split two days ago. I loaded CELG chart and because SierraChart now downloads historical data from SC server and not IB, the pre-split data shows up and the chart is now distorted. Before, all I do is delete all data and download and the adjusted post-split prices from IB are downloaded. Is there an easy way to fix this?
Date Time Of Last Edit: 2014-06-30 07:16:57
force_dl_from_ib.jpg / V - Attached On 2014-06-30 07:11:47 UTC - Size: 157.2 KB - 332 views |
[2014-06-30 08:53:49] |
We are working on implementing automatic stock split adjustments. We have adjusted the historical data for this symbol. Re-download it. Let us know if there any others. But we should be catching up on this with the next two weeks. There is not a way to prevent the downloading of US stock data from the Sierra Chart Historical Data Service when using Interactive Brokers. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-06-30 10:49:05] |
Ok thanks.
