Date/Time: Wed, 30 Oct 2024 22:56:07 +0000
Bid ask staking pulling
View Count: 280
[2023-06-02 22:16:09] |
User695692 - Posts: 6 |
Hi Is there any way to see bid and ask pulling and staking on main chart?i can see on dome but can I see its volume bar on top or bottom of candle on chart? |
[2023-06-02 22:17:48] |
John - SC Support - Posts: 35639 |
We are not sure exactly what you are wanting to see. The sum of the Bid/Ask Pulling/Stacking can be viewed in the Numbers Bars Calculated Values 2. You can then display those values where you want. Refer to the following: Numbers Bars: Numbers Bars Calculated Values 2 Subgraph Descriptions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
