Date/Time: Thu, 28 Nov 2024 03:43:14 +0000
Price Bar Does Not Update While Price Value Updates
View Count: 246
[2023-06-02 13:14:24] |
User489473 - Posts: 10 |
As shown in the screenshot, the price bar for GC does not update, it stopped around price level of 1996, while the price value (highlighted in white) updates on the right frame of the chart window, being at 1987.0 when the screenshot was taken. I tried "delete and download data" however it didn't solve the issue. Charts for other symbols update properly. Even if I open a new chart for GC, the new chart updates properly. This issue only exists with existing charts of GC. How to fix this ? https://www.sierrachart.com/image.php?Image=1685710662390.png |
[2023-06-02 13:36:49] |
Sierra_Chart Engineering - Posts: 17199 |
Refer to: Intraday Chart or Chart Bars Not Updating | Blank Intraday Chart | "Currently no data to display" message for Intraday Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
