Date/Time: Mon, 16 Sep 2024 19:13:07 +0000
Session Time questions
View Count: 1019
[2014-06-30 00:18:05] |
User53441 - Posts: 17 |
If I want to have different session times for each instrument (futures,forex,stocks) can this be done using SC Historical data feed or is a real time data service required?
[2014-06-30 00:36:15] |
You can set the Session Times through Chart >> Chart Settings no matter what Data or Trading service you are using Sierra Chart with. Press the Help button on the Chart Settings window for the complete documentation. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-06-30 03:10:47] |
Thanks but this only seems to work for intraday charts, if I want to choose the session time for daily, or weekly charts is that doable?
[2014-06-30 04:52:33] |
No. Although you can use an Intraday chart for this purpose. Refer to this help topic: https://www.sierrachart.com/index.php?page=doc/helpdetails13.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
