Date/Time: Thu, 28 Nov 2024 03:57:06 +0000
Alerts Pop Up Window
View Count: 353
[2023-06-02 02:32:10] |
User276813 - Posts: 64 |
I have several indicators that are set to play an alert sound. SOME of them also are included in an alert pop up window... some do not. How do I make it so that ALL alerts show up in the alert pop up window? Since I have multiple alerts, I like to know which study the alert is for and like the pop up window rather than opening up the alert manager and scrolling to the bottom to see which alert it was.
[2023-06-02 10:02:02] |
Sierra_Chart Engineering - Posts: 17199 |
This is controlled through the settings for each Alert Number: General Settings Window: Alerts (Global Settings >> General Settings) And refer to: General Settings Window: Add Alert to Compact Alert Popup Window (Global Settings >> General Settings >> Alerts >> Additional Settings) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-06-02 10:02:06
[2023-06-04 18:29:11] |
Thanks! It's under "Additional Settings" -> Add Alert to compact alert pop up window = yes
[2023-06-05 07:41:06] |
Yes.
