Date/Time: Mon, 16 Sep 2024 19:18:42 +0000
Why Would I Not Be Able to Hide The Lines of an Indicator?
View Count: 1473
[2014-06-29 15:31:27] |
cmet - Posts: 548 |
If I set some of the Subgraph settings on the Vortex Indicator to "ignore" or "hidden", they do not disappear. I realize this is a user defined study but is there a simple way to open up this indicator code in SC and add or fix this problem so that I can hide Subgraph parameters I don't need? |
[2014-07-01 06:18:12] |
The code is attached. Currently with the way that it is programmed, it will do what you described. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
VortexIndicator.cpp - Attached On 2014-07-01 06:17:40 UTC - Size: 8.04 KB - 480 views |
[2014-07-06 21:31:11] |
cmet - Posts: 548 |
Can't create a dll from this. "None of the selected source files contains the SCDLLName line at the top of the file" |
[2014-07-06 21:34:18] |
cmet - Posts: 548 |
Nevermind, found the solution #include <string> #include "sierrachart.h" SCDLLName("VortexIndicator") |
[2014-07-06 21:40:53] |
cmet - Posts: 548 |
However, this does not solve the problem. I cannot hide any of the lines on the indicator. It automatically turns them back on when you hit "ok" Here's is a video showing the problem: http://tinypic.com/player.php?v=96cdad%3E&s=8#.U7nCQ7H5eXg Is there something simple I can change in the cpp file that will allow me to do this? Date Time Of Last Edit: 2014-07-06 21:41:30
