Date/Time: Thu, 28 Nov 2024 03:50:27 +0000
[Programming Help] - My charts disappear from my screen when ever i press play to play the market replay..
View Count: 317
[2023-06-01 18:08:46] |
User737325 - Posts: 2 |
My charts disappear from my screen when ever i press play to play the market replay.. please i need help.. is it some settings or is it my computer? my chats and the drawings disappear once i press play.thanks in advance. |
Attachment Deleted. Private File |
[2023-06-01 21:20:29] |
The charts first reload when you start a Replay, so they will go blank while they are loading. Also, we do see what might be a bar at the far left, which would also be normal if you have started the replay from a specific time and date. One other item of note, since you are doing "All Charts in Chartbook" it can take a minute or two for the replay to actually get rolling within a specific chart. Give it time to see if things get moving. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-06-01 22:35:50] |
j4ytr4der_ - Posts: 938 |
In case this is related, I noticed some time back that on a multi-chart replay, the replay would actually start instantly, and any charts which has a lot less calculating going on would begin to play back, but others would still be loading. This caused weird issues at times. At some point there was a "Pause on start" option added, and I always use that now. This way any time I start a multi-chart replay, nothing begins playing until I hit play a final time, once I'm sure all the charts are ready. Helps tremendously in my experience.
