Date/Time: Sun, 27 Sep 2026 06:18:21 +0000
Lowest/Highest of week/month/qarter/beginning of yar to date
View Count: 1418
| [2014-06-29 13:29:57] |
| Dom7364 - Posts: 258 |
What is the way to display a horizontal line for highest since begiining of the year to dat, highest since begining of the month to date, highest since begining of the week to date, until it is crossed and therefore rest (a bit like a naked levl)? Thanks Rgds |
| [2014-06-29 20:21:10] |
The closest we have is going to be the Previous OHLC-Variable Period study: http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s294 It will draw High and Low lines across any time period for either the current or prior period. The lines do not stop when they are crossed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
