Date/Time: Thu, 28 Nov 2024 03:58:16 +0000
Strange Rollover
View Count: 314
[2023-05-31 21:44:06]
User146848 - Posts: 121
Greetings,
what infos do you need to be able to explain to me why this monthly bar for june starts at end of may...two days too early.
It messes up my indicators.
Thx
image31-05-_2023_13-23-56.jpg / V - Attached On 2023-05-31 21:43:48 UTC - Size: 93.46 KB - 85 views
[2023-06-01 11:00:34]
I add two more pictures to make the case more clear.
Is this normal? Can anyone replicate this. I tried several time the redownload...nothing works.
THX
imageGold Cont Vol #1.jpg / V - Attached On 2023-06-01 10:59:43 UTC - Size: 96.06 KB - 88 views
imageCont Setting NONE.jpg / V - Attached On 2023-06-01 11:00:04 UTC - Size: 77.68 KB - 83 views
[2023-06-01 12:34:57]
Sierra_Chart Engineering - Posts: 17199
We are not able to reproduce this. This is what we see:
https://www.sierrachart.com/image.php?Image=1685622877258.png
Provide us that particular chart following these instructions:
[2023-06-01 21:44:57]
After your answer i did delete all files manually. After the download everything is fine.
Thanks...
