Date/Time: Thu, 28 Nov 2024 03:42:17 +0000
seeing 0 quantity in options .scid records
View Count: 255
[2023-05-31 20:40:03]
voided - Posts: 45
I recently noticed an apparent error in one of my programs that uses the .scid files when looking at the an options symbol. After investigating I noticed that there are "0" values in the TotalVolume field for many records. An example symbol is "LON23 C7500.FUT_OPT.NYMEX" for today, 2023-05-31.
Is this what you see? I do not see this in records for underlying futures contracts. My expectation is that each record represents a trade with nonzero volume.
Note that I have everything configured for tick-level storage and the futures contracts work fine.
Date Time Of Last Edit: 2023-05-31 20:40:50
[2023-06-01 14:27:05]
Sierra_Chart Engineering - Posts: 17199
What is the Bid volume and Ask volume fields for the record?
[2023-06-01 20:26:38]
voided - Posts: 45
Here are the most recent ten records in the file as of the time of posting:
DateTime Open High Low Close NumTrades TotalVolume BidVolume AskVolume
3894812545401000    0.0    65.0    63.0    64.0    1    0    0    0
3894812545401001    0.0    65.0    63.0    64.0    1    0    0    0
3894812545574000    0.0    65.0    63.0    64.0    1    0    0    0
3894812545574001    0.0    65.0    63.0    64.0    1    0    0    0
3894812545627000    0.0    65.0    63.0    64.0    1    0    0    0
3894812545627001    0.0    65.0    63.0    64.0    1    0    0    0
3894812547356000    0.0    65.0    63.0    64.0    1    0    0    0
3894812547356001    0.0    65.0    63.0    64.0    1    0    0    0
3894812547939000    0.0    65.0    63.0    64.0    1    0    0    0
3894812549176000    0.0    65.0    63.0    64.0    1    0    0    0
The file also includes normal records that have a non-zero TotalVolume, matching either the BidVolume or AskVolume, as expected. But for some reason there are many records like the ones above, as well.
