Date/Time: Thu, 28 Nov 2024 03:44:19 +0000
ES Footprint Chart data discrepancy on bid/ask
View Count: 294
[2023-05-31 02:14:43]
Oxcap - Posts: 65
I tried searching the support board but did not see any information related to my issue I have.
I use numbers bar study using a range per bar footprint chart. I am trying to determine why the footprint does not match with my desktop vs laptop chart. I attached a screenshot. The example is a screenshot with my laptop on the left circle and desktop on the right circle from 5/30/23 RTH trading session. You will see that the bid/ask do not match.
How can I match my desktop footprint chart to my laptop on the left?
Let me know if you may need more information for clarity.
Thanks,
HN
imageES FOOTPRINT CHART EXAMPLE.png / V - Attached On 2023-05-31 02:06:32 UTC - Size: 414.28 KB - 72 views
[2023-05-31 08:11:40]
Sierra_Chart Engineering - Posts: 17199
Refer to:
Working With Charts: Resolving Differences of Chart Bars Between Charts
[2023-06-01 04:24:47]
Oxcap - Posts: 65
It was the Intraday Data Storage Time Unit setting. Thanks
[2023-06-01 10:54:36]
Yes we figured that.
