Date/Time: Mon, 14 Sep 2026 21:28:06 +0000
2 different exchanges?
View Count: 1349
| [2014-06-28 20:58:12] |
| User64687 - Posts: 6 |
Hi! I'm pretty new with this, so maybe it's a silly question, but I would like a way to plot a line which would be the difference (in %'s or $'s) between two exchanges. so for example, I want the value of a BTC on BTC-china to be subtracted from the value of a bitcoin on bitstamp. Is this possible? Thanks in advance :) |
| [2014-07-02 04:05:59] |
To get you started with this, you can calculate the difference by using the Difference (Bar) study. Refer to the documentation for here: https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s3 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-07-04 20:00:27
| [2014-07-04 12:51:52] |
Thank you for your response, I already found that 1 and followed every instruction, however when I select the difference (bar) study, the chart I want to add isn't in the "chart 2 number" options. I have the other chart open & saved. |
| [2014-07-04 18:29:29] |
Here is a print screen with my problem, I tried with 10+ charts, same settings (candle, 1hr etc) but still I always only get those 2 as options... |
| Attachment Deleted. |
| [2014-07-04 20:01:44] |
As the documentation states, the charts that the Difference study references must be within the same Chartbook. They cannot be in different Chartbooks.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-07-04 20:02:12
