Date/Time: Thu, 28 Nov 2024 03:40:03 +0000
2nd PC
View Count: 286
[2023-05-30 23:27:50] |
User946492 - Posts: 7 |
I have installed Sierra on a 2nd PC which I intend changing over to At login I have entered AC105980 a/c and a password which I had recorded but it comes back as invalid and I cannot read password on 1st PC could you please help Thanks Graham |
[2023-05-31 08:19:17] |
Sierra_Chart Engineering - Posts: 17199 |
We have reset your Sierra Chart charting and trading software password. It has been sent in a separate e-mail to your e-mail address. If you did not receive it, let us know. Your e-mail provider may have filtered the message and placed it in a junk mail folder. For complete Login instructions and help with possible Login problems, refer to: Sierra Chart - Software Login Instructions If you continue to have a problem logging in, then let us know and provide us with the *exact* error message you see after pressing the Login button. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
