Date/Time: Mon, 25 Nov 2024 18:49:46 +0000
Problem with cell J111 Pause Chart Replay
View Count: 293
[2023-05-30 22:25:15] |
j4ytr4der_ - Posts: 938 |
I'm not sure when this cell was added, I swear it didn't used to be there but maybe I'm just getting old. I've been using it off & on now in my spreadsheets and I absolutely love it! So fantastic to be able to put the order flow condition I'm looking for in there, turn the speed up to 60x, and just let it rip until it finds the spot I need to look more closely at! Unfortunately, it seems to break with a multi-chart replay. Both charts will initially pause at the appropriate moment, but when you resume the replay... only the chart that has the Spreadsheet System on it, unpauses. If you select the other chart (that is now not playing), it will show on the replay control panel that it is playing (shows Pause on the button), but it you hit pause while on that chart, the first chart starts playing. Something definitely seems slightly broken here. Hoping this can get looked at and fixed, as this is such a fantastic feature on single chart replays. Would love it to be reliable on multi-chart ones too! |
[2024-02-03 14:58:02] |
fxzen - Posts: 14 |
Thank you for this, I finally figured out what broke all my replays. I narrowed it down to the spreadsheet study, and then deleted all formulas and still had the problem, and kept searching until I found your post. When these new rows were added, old values were not removed. So there was old values in there causing the spreadsheet to constantly pause replays Date Time Of Last Edit: 2024-02-03 14:58:22
[2024-02-06 21:09:37] |
Sierra_Chart Engineering - Posts: 17174 |
We will check on this. Regarding post #2, refer to this input: Spreadsheet Study Inputs: Clear Unused Column I Names Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-02-06 21:10:25
