Date/Time: Thu, 28 Nov 2024 03:46:34 +0000
Hiding Price Format display in Trade DOM
View Count: 293
[2023-05-30 20:46:19] |
ElDuderino - Posts: 13 |
Hello-- Just above the summary number at the top of the Sell column in all my Trade DOMs there appears a number that indicates the tick value (e.g., 0.25 for the ES, 0.'1 for the ZB, etc.). How can I hide or disable that number? Thanks. |
[2023-05-30 20:55:27] |
We really need to see an image to fully understand the particular item you are referencing. But, the item we think you may be referencing is part of the Chart Header. Refer to the following for how to change these items: Global Settings Menu: Customize Chart Header - Trade DOM (Global Settings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-05-30 23:15:50] |
John, Thanks for your timely response. However, I was not asking about chart headers. Please see the linked chart with overlay image of my DOM for the ES. Note the figure "0.25" in black font at the top of the numbers in the red Sell column (just above the number 354 in yellow). That is the number I was referring to and is what I want to hide or disable. https://www.sierrachart.com/image.php?Image=1685487621520.png |
[2023-05-31 14:36:02] |
That is not the Tick Size, it is the "DOM Spread". Set the following option to "No": Global Trade Settings Windows: Display DOM Spread (Global Settings >> Chart DOM Settings >> Other >> Other Settings) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
