Date/Time: Thu, 28 Nov 2024 03:58:09 +0000
Transferring Studies from one subinstance to another
View Count: 434
[2023-05-30 13:13:06]
Steve Leon - Posts: 301
I am trying to transfer some studies from one subinstance to another.
I thought that when i closed the platform down and restarted it the the studies would show up in the main instance but they did not.
i also tried to send the chartbook file while my main instance and other suninstances were running and i could not find the chartbook in any of the instances after trying to send it this way.
Finally i tried to find the chartbook in file explorer and move it from one subinstance to another; but could not find the chartbook in those subinstanaces (i was looking in Data folder under subinsintance - probably looking in the wrong place)
Can you try to help me understand what i have done above and why it did or did not work. and also help me get the studies into the other subinstance
Thank you
[2023-05-30 13:30:34]
j4ytr4der_ - Posts: 938
Nope, once the instance has been created, it's a separate entity. Any chartbooks, studies, study collections, etc. have to be manually copied into the sub-instances any time you want them there. You would do this in Windows, not within Sierra.
