Date/Time: Thu, 28 Nov 2024 03:42:57 +0000
Rhitmic
View Count: 283
[2023-05-30 09:51:25] |
User904434 - Posts: 54 |
I can not see market depth using Rhitmic data feed? can you support me?
[2023-05-30 09:55:59] |
Sierra_Chart Engineering - Posts: 17199 |
You do have the CME exchange with market depth activated on the Denali Exchange Data Feed but it is not being used for this reason: The reason you are not getting real-time data from the Denali Data Feed, and historical data from the Denali Data Feed in the case of when using an external Trading service (Rithmic, CQG, Interactive Brokers), from the CME Group of exchanges is that you activated the *Non-Professional* exchange fees. However, you have not verified in the last month that you have a live, funded, futures trading account, which the CME needs in order to allow you data at the lower priced fees. Refer to the "Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges" section here: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges Rithmic paper trading or trading evaluator accounts are not considered a live funded futures trading account. Refer to the following for instructions on how to connect once a month to your *live funded* trading account to qualify for the lower-priced exchange fees: Real-Time Exchange Data Feeds Available From Sierra Chart: Connecting Only Once a Month to Trading Account to Support CME Group Exchange Fees If you do not have a funded trading account or one with a supported Trading service, then refer to this solution: Easy Solution to CME Funded Trading Account Requirement Consider the above solution to avoid this problem in the future. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-05-30 10:46:17] |
Thanks I understand - It means if I pay my money to as an exmple to AMP (CQG) Broker I will get acces to real time data. This time I wanted to use Earn 2 Trade - thats why I can not see market depth, although once I traded with them and everything was ok.
[2023-05-30 16:11:27] |
Your account still has not updated the "Verified Until" date. You can view this date at the following link: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges Prop Firms like Earn2Trade do not count towards the Non-Professional requirement for the CME Group since you are not trading your own funds. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
