Date/Time: Mon, 16 Sep 2024 19:22:59 +0000
Difference tool
View Count: 1042
[2014-06-28 15:50:05] |
tellerbe - Posts: 109 |
I want to use the difference tool to show the difference between closing price of a bar and keltner channel. Can't figure it out. TE |
[2014-06-30 18:24:32] |
For this you will need to use the Study Subgraphs Difference study. Here is the documentation for it: http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s185 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
