Date/Time: Thu, 28 Nov 2024 03:42:17 +0000
Different session times on tick chart
View Count: 371
[2023-05-30 00:40:39] |
User377189 - Posts: 172 |
i have setup intra-day chart with bar period type set as number of trades per bar I would like the bar to be colored a different color when a new session starts or a session ends Ex.: When Asia session starts i want the bar to be colored red and when Asia session ends i want the bar to be red When Europe session starts i want the bar to be colored yellow and when Europe session ends i want the bar to be yellow When US session starts i want the bar to be colored blue and when the US session ends i want the bar to be blue How can i set the charts to display the above? |
[2023-05-30 08:12:48] |
Sierra_Chart Engineering - Posts: 17199 |
You can do this with the Time Range Highlight study: Time Range Highlight Or look at using the Color Bar Based on Alert Condition study: Color Bar Based on Alert Condition Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-05-31 13:33:02] |
This highlights the area from start time to end time...i want just the bar to be colored a different color at Asia-Europe-US opens and closes
[2023-05-31 15:21:15] |
You need to use the Color Bar Based on Alert Condition then. Refer to the following: Color Bar Based on Alert Condition For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-05-31 22:19:36] |
Ok i figured how this works and set it up on the main instance of sierra chart While trying this on the other instance of sierra chart this study did not work i did the simple test that is mentioned in the study document "The very first formula you should use to simply see how this study and how formulas work is =1 or =TRUE. This will color the bars or background in the chart and then you can go from there to a more advanced formula." When i did this the bar colors do not change. In the main instance when i did this test all bars colors had changed |
[2023-06-01 13:29:44] |
i got this to work on both instances of sierra chart Is there a way to show on chart how many bars are being displayed based on the level of zoom? |
[2023-06-01 15:49:13] |
There is not a built-in tool that will give you this number. You could create a custom study to do this. Refer to the following: Advanced Custom Study Interface and Language (ACSIL): Introduction For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
