Date/Time: Fri, 25 Sep 2026 01:58:26 +0000
Transferring Sierra Chart Settings from "normal" SC to Non-.NET/CLR SC
View Count: 1486
[2014-06-28 15:40:42]
tobi - Posts: 351
Transferring Sierra Chart Settings can easily be done following these steps:
http://www.sierrachart.com/index.php?l=doc/helpdetails15.html
Can this also be done when changing from "normal" version SC to "Non-.NET/CLR" version SC?
Is there anything to note?
[2014-06-28 18:29:35]
Yes. Other than spreadsheets, from the user perspective, functionally they are the same.
No.
[2014-06-28 18:41:27]
tobi - Posts: 351
Ok, thank you!
What are the differences in the spreadsheets? Could you please point me to the relevant information how to use the new spreadsheet functionality.
I've been off for a few months and would like the switch to the Non-.Net/CLR version and convert my chartbooks where in most of them I do use spreadsheets. Thank you!
[2014-06-28 19:38:37]
We cannot answer this question now because the new Spreadsheets have not officially been released.
