Date/Time: Thu, 28 Nov 2024 01:25:12 +0000
Configure button setting for the control bar doesn't save
View Count: 342
[2023-05-29 09:44:26] |
User246799 - Posts: 13 |
Hello, I am running the version 2502 of Sierra and I have some troubles with the button setting of the control bar. - I select the line tool from a button on the control bar - Then I go to configure button by right clic on a tool cfg button - For all my buttons (TC1 to TC7), I de-select the "opaque label background" box (the box is not checked anymore) - I apply the changes and I save the chartbook. - This settings works as long as Sierra is open - If I close Sierra and relaunch it, then the setting is lost and the "opaque label background" box is checked again. The setting has not been saved and I have to do again the changes. Any solution to solve this and save definitely this setting ? Thank you. Jerome |
[2023-05-30 10:07:05] |
Sierra_Chart Engineering - Posts: 17199 |
This is being reviewed.
[2023-06-07 07:39:45] |
Hello, any news for me about this issue ?
[2023-06-09 19:05:10] |
This has been resolved. Update Sierra Chart to the latest release: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
