Date/Time: Wed, 27 Nov 2024 20:42:11 +0000
Black tiny window in the
View Count: 806
[2023-06-30 20:04:04] |
John - SC Support - Posts: 36344 |
Yes, we understand. The reason you are not able to see the text when it is black is because the text is also black. So it is black on black. If you want the text to remain black, then you would need to change the color of the "Trade DOM Background Color". The other option would be to change the colors of the "Cumulative Last Size Text Bid/Ask Trade" which changes the text color. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-06-30 20:29:46] |
User101919 - Posts: 27 |
Yeah, but I did those, and nothing is happen. What else can I do? :(
[2023-07-03 12:32:51] |
What is the color of the text options at this point?
[2023-07-03 14:51:54] |
Ok, I misunderstood: The problem has solved. You were right, but the point is: I had to change those settings in *MY* Graphs (not in the general I mean). Now I see everything ok. Thank you for supporting and Best of the best regards. Elad. |
