Date/Time: Thu, 28 Nov 2024 03:41:26 +0000
[Programming Help] - Number bar showing zero at the end
View Count: 436
[2023-05-28 18:28:56] |
User928353 - Posts: 8 |
Hi i want to show numbers bars which have zeros in the end at high and low i followed this thread Numbers Bars highlighting and got the zero high number but when i put these formula to get the same result for low it didnt work =AVAP(H, 0)=0 =AVAP(L, 0)=0 =AVAP(0, L)=0 I tried all of these but the dont work can you help me with the alert Thank you |
[2023-05-30 14:22:46] |
The following formula will give you a True result when the Ask Volume at the Low is zero: =AVAP(L, 0) = 0 For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
